- May 12, 2019
- 15
oooo the quoting system on this platform is lovely... I'm used to vBulletin...
Is it best practice to get an R8 or can i just get a straight shank and put it in a collet? Seems like a super simple tool so i wouldnt mind an import. I assume the head size doesnt dictate the diameter as you can extend it out a bit more?
As for sizing. 3/8 x 3" or 4" optimal. or should i just upsize to 1/2".
I assume that's all the add on after the cost of the mill?
Yeah I picked up some USA HSS from an estate sale which are delightful. I just dont have the full range of the master set. Split point matter if you are spot drilling?
Yeah i for sure get that. but lets say i was facing a full side of something or a top. I feel one of the 1" tools i got with a light pass would be more rigid than a smaller one. but maybe too light a pass would have a poor finish. I'll experiment and see what's up. As far as the carbide. I wasnt seeking it out. My lot acquisitions had me come into a lot of it as you can see from my pics. I was just wondering if i could use it to the same extent as HSS or if it only works well getting cranked up a bunch. Otherwise i might try to sell or trade some.
Thanks for the tip!
I'll give it a whirl after I fabricate a new key for it. For the level of stuff I'm doing it should be passable for now. saw an older USA one for sale locally but by the time I buy or fabricate a backplate its basically the cost of a new purpose built import one. We will see. Autocross season is buttoning up so i'll have some more focus on the shop.Yes, I forgot the 4 jaw that comes with the G4000 is awful.
Thanks for the tip. I'll put it all on the purchase/trade list.There are lots of cool things to spend money on, but the ER collets are something I actually use fairly often.
I'm just using a simple one that can cut about a 3" pass with a 3/8" HSS bit. I just ground it myself and it works great.
For HSS blanks, start with some import HSS.
would probably be $3k including good ballscrews and all the conversion hardware. Add $1k if you want DMM servos.
Wish I'd spent $100-200 extra to start with so the drills were better quality. Again, split point would be a must IMO.
ut you won't be able to really "use" the full capability of the tool. I think I can get close to actually "using" the full capabilities of 1/4" tooling in steel. If you're paying for carbide,
Large Depth of cut (e.g. .750") and small width of cut (e.g. 0.030") seems to work best on this machine if you get the choice.
Thanks for the tip!
