- Nov 10, 2013
- 832
I have a KO Lee 6x18", it's been a great grinder for me. The table lifts straight off the top (just a note in case you need to move it) held in place by gravity. Under the table are oil pockets with rollers sitting on a piece of spring steel. The rollers pick oil up from the pockets and spread it onto the ways. The first thing I had to do was make several sets of rollers and springs to replace the missing ones.
I replaced the spindle bearings in mine too, there is a trick to how the spindle comes apart but I'd have to read my old thread again if I had to do it over again. The bearings were pretty cheap, I just bought the same ones that were already in the spindle from a local bearing supplier. I had to replace a motor belt at some point too, nothing special. Manuals are on the web in PDF form, just look for KO LEE S618 PDF and it should pop up.
I don't remember the table being that heavy but I didn't have the chuck on it when I was working on it.
