Hi, I'm new to machining and I'm trying to hold steel drill rod (diameter between 1/4 inch and 1 inch) vertically for machining the ends to make embossing dies. The machining will be done with very small end mills (about 1mm diameter) so there is not a lot of force on the workpiece. I'm wondering what you would recommend to hold these cylinders? I don't currently have any tools for holding them (or even know what tools to use!) beside some nuts and bolts. I do have a small table top TAIG mill and lathe, so I can face the ends of the drill rod as well as machine aluminum fixtures. Any advice is appreciated! Thanks!
Hey Silverworker,
Here's a fixture I made to do exactly what you are describing. Just a squared up hunk of 1 x 2 6061 T6, with a couple of v-grooves, and tapped holes. The clamp strap fits both v-grooves. The end v groove is pretty close dead center of the width, and marked with the dimension. The spherical washers are a really nice touch, but they aren't really necessary. Has come in really handy for small work many, many times!
Regards,
Bob
