I read your thread Ray, and I must say I wish I had done as thorough a job researching this project as you did. You made a really nice oven!
I tend to have a lot of enthusiasm and little patience, which has worked to my detriment more than once. This isn't the first project I've gotten halfway through and realized a major design element was overlooked.
Nevertheless, more power and more insulation might be able to save this oven from the dumpster. I am going to rewire it for 230 VAC and wind a new element. I have plenty of room in my electrical box for a new 30 amp breaker, and it's right in the shop.
I'm thinking I might line the inside of the oven with some fiber board, both to hold the element and to give a little more impedance to ever escaping heat. Do you guys think it's worth the trouble?
I've got some aluminum sheet metal, but not enough to cover the whole thing. Cement board?
Thanks for all the input!
Ted
Personally, I hate the cement board but, it works. It's starting to crumble and will need to be replaced. That will be minimal effort and expense.
The oven works well and is used frequently. Along the way, the pyrometer went bad and needed to be replaced. No big deal.
I wrapped the whole oven frame in one more layer of that insulation (3 layers total), stuffed it in that cement board enclosure and it does not get terribly warm on the outside walls. Of course, if you touch the metal door frame, you'll get a 2nd degree burn -this is to be expected. Most everything I do needs temps of 1525 and it takes about 50 minutes to hit that temperature. Once I accidentally set it to 1650 and it hit that with no problem. The coils have been replaced twice and it was due to using carburizing compounds. The fumes weaken the wire. Now, I use argon purge and the coil has lasted a couple years now. They are cheap to replace.
I would some day like to make a smaller one. I hate the cement board and the way it feels but, like I said, it works... It eventually crumbles due to the heat but, mine has been holding up all these years well-enough to be functional.
For your setup... I'd cut the legs off, wrap a layer of the insulation around the whole thing, build an enclosure around that, set it on some bricks, and call it a day.
Ray
EDITED: To fix a broken sentence and clarify a statement about layers of insulation.
