GE Lathe Motor Disassembly, with no doubt wiring questions later
Does your manual have electrical diagrams? I guess there's no motor reversing switch on this lathe?
The pump should be ok. It will run a bit faster on our 60 cycle power
@Ulma Doctor I'm having trouble with the 1RS bearing. Amazon shows it to be a tapered bearing. I found another with the prefix 205F. It has a seal on one side and it's open on the other like the ones I removed from my motor. Amazon showed a 6205-2RSC3.
My lathe has a reverse switch. Colchester commonly sold this lathe with a 3-phase motor. 220 1-phase was optional and more expensive. They also offered a 2-speed motor. Your post reminded me that I purchased a quality reprint of the manual. Here are the wiring diagrams. I believe I have a single-speed motor, but I'm not sure. I posted the ID plate in my first post. Would a 2-speed motor list two RPM's? I don't know how to tell.
Yes the GE motor you have is single speed. I don't see the starting cap though-
Before you re-mount the motor we should go over the windings with your meter and label them while it's on the bench
-Mark
The 6205-1RS bearings are better than the 6205-Zbearings, the 1RS versions neoprene seal seals out moisture as well as dust. The Z shield is only good for sealing out dust.
SKF or Timken are good brands
Which ever bearing that you choose will outlive you, it does not matter much
-Mark
The starting and run caps are held in the underside of the case with spring clips. I haven’t tried to remove them yet.
You can pick one of the seals out when you get the bearing if you get the 6205-2RS
Would there be an issue running them as they come? I see the reason for one open face, to re-grease. Are the ones with two seals intended to be maintenance-free? Perhaps heat build-up?
You can certainly run them as they come.
They are considered lifetime lubricated.
Too much grease is not ideal for longevity.
