Be careful tilting the head until you figure out what’s going on with that worm gear.
If it’s in there but inop you probably won’t be able to rotate the head at all.
If parts are missing or damaged it could just flop over to one side unexpectedly when it begins to tilt.
I was definitely worried about that happening when I went to tram the head to the table.
I chucked a long-ish 5/8 scrap rod into the head. Instead of clamping the table vice onto the rod, I tightly clamped a matching pair of scrap steel blocks on both sides of the rod in the vice, leaving the rod free to move, but only about an inch either way before being stopped by the blocks.
I then carefully loosened the four face bolts on the head until it was able to rotate. It rotated freely, within the bounds of the vice & rod.
I straightened the head by eye, and tightened the bolts some to hold it still.
I then carefully removed the rod & vice, and chucked up the starret indicator to sweep the table. But before I did that, i tightened a ratchet strap around the motor to the back of the ram, as a little insurance in case I lost control of the head. I should've used my cherry picker instead, but it wasn't handy at the time.
I then very-carefully loosened the bolts to the same point where i could just nudge the head earlier. I would look at the dial, tap the head some with a brass hammer until the dial moved, tighten a head bolt, then sweep the table. Then carefully loosen the bolt and do it all again.
Long story short, i got my head trammed in to the table! I'm confident it's within a thousandth all 360* around, and maybe within a half thousandth (reasonably confident).
I'm pretty confident that it's within a half thousandth in each axis separately.
Got my vice remounted and aligned too.
I neglected to take pictures of the setup, only videos after tramming.
