- Sep 20, 2019
- 1,396
I bought this Colchester Master 6.5" a couple of years ago. It hasn't seen much use, and I knew when I bought it that a previous owner bypassed a few factory switches and that it only ran in forward. This weekend, I thought it was time to dive into it as I'd like to put it back in factory condition to include the coolant system. The person who rewired it was a butcher - crimp caps, bizarre wire extensions - a general fire hazard.
I pulled the motor last night and put PB Blaster on the screws, bolts, and spindle ends. I have two screws giving me fits but they don't appear to be a present issue as far as disassembly as I can't figure out what they do. They don't appear to extend through the housing. They screw into the case at both ends of the spindle, and they are at 12 and 6 o'clock positions. I've tried several cycles of PB, tapping, heating to no avail.
The pulley in front came off without issue, but I can't get the back of the housing off. There is a single wire that extends from the middle of the casing, I assume from a coil to I think the clutch? I beat on it some and it doesn't want to move. I can't figure out a way to press it out, and I don't want to break anything. Here are pictures of the assembly and the ID plate should it help. I appreciate your help.
I'd swear a mouse lived in this motor at one point. There are numerous pieces of shredded paper inside. The front bearing looked and felt fine except for the dried grease. The backside, however, had hair or another type of fibrous debrief stuck in it. I'm not sure how I can pull it as it sits quite a ways down the spindle, but I plan to replace the bearings while I'm in there.
