- Nov 17, 2020
- 1,723
Emco parts are cheap compared to Deckel parts, but the good is there are companies that still support them, just expensive.Emco parts are expensive because they are no longer made and you are competing with others across the country. If you see something you need, jump because it won't last long.
Mine has the big bore. Did you purchase yours new?I believe only Imperial models were commonly imported into the US, although you could certainly order metric lathes. The camlock models came with the 1" spindle bore but the models made right before they switched to the CD model also had the "big" 1-3/8" spindle bore that was standard on the CD.
Emco doesn't show 480v, they show 440v, model number 5803GP in inch modelit also has a 480v three phase motor on it right now..
i am just going by what he has listed in the ad.. my plan would be to go 220 singleMine has the big bore. Did you purchase yours new?
@mikey did you put a DRO on yours? If so.. which one did you put on it? Or which one would recommend?
thanks for the on the info.... and yes i am a vet tooI do not have a DRO on any of my machines but I want to; just haven't gotten around to it. I wanted to go with a Mitutoyo DRO because I have come to trust the accuracy of this brand but I just learned that I probably won't be able to cut the scales to length so that went out the window. I will probably go with DRO Pros when I jump, mostly because if something went wrong then I have support. I know I can go cheaper with other sellers but as a veteran I like supporting a veteran-run American company, even if they're selling Chinese stuff; for me, it isn't just about money.
it appears that they are a "cult" item.. is that right?Mine is a CD so big bore by definition, although I'm not sure I would call 1-3/8" big.
No, I bought it with less than 100 hours on it. The guy intended to use it for gunsmithing but for some reason he lost interest.
Back when he bought it, the lathe cost almost $7k and that was with no accessories other than a 3 jaw chuck, and then he had to ship it to Hawaii. He bought the steady rest but not much else. I had to tool it up from there and it is now fully tooled up other than the taper attachment that I won't use and the grinder that I also won't use. I could just about buy two PM1340GT's with what I have invested in this lathe so some might think I'm crazy but then again, I have one hell of a lathe. Given the machines you have, I'm sure you understand.
