- Nov 17, 2020
- 1,723
cult might not have been the right word.. but it was the word that came off the ends of my fingers at that time.. but i think in jest, you know exactly what i was meaning.. yes.. a following.. but that term didn't come to me at the time i first coined my other response.. i am looking forward to picking it up and getting it going..Cult? Hmm, maybe, but Emco machines are not like most machines and your lathe was built to a DIN tool room standard. Doing that is not cheap because every single aspect of the machine has to be done in a way that would pass inspection if they were to actually inspect it. I don't own the DIN standard sheet because it costs several hundred dollars; I keep hoping someone will copy it to the net.
Emco owners tend to be fanboys because the machines earn it. Wait, you'll see what I mean. I have run SB13's, a Sheldon and several Chinese lathes before and none of them even come close to the smoothness and precision of a Super 11. My lathe runs at around 72dB at full speed so you can stand next to it and have a conversation. I balanced a nickel on the headstock while it ran at full speed and the nickel didn't move. It has zero spindle run out, zero backlash on the cross slide and the compound, is hardened everywhere it counts and can take a 0.200" deep cut in mild steel with a HSS tool without gearing down; it can go deeper if you do gear it down a step. I measured the movement of the compound feed with a Compac 215GA and it is accurate to the tenth in movement; this matters when you're cutting a class 3a thread. There are little touches that you wouldn't normally notice, like a hardened dowel pin in the saddle where the carriage stop pin contacts it; makes for a very solid top and results in zero wear on the saddle casting. It has height adjusters fore and aft under each foot of the bed to allow for very fine leveling adjustment. The rib configuration of the bed is very rigid given its width so the lathe is very stable, very stiff, very accurate. It will also cut most common Imperial and Metric threads without resorting to the change gear set.
You are going to see how this lathe is constructed when you clean yours up. Everything fits, nothing needs to be forced or heavily torqued down. The machining is just excellent on this lathe and the quality of the castings is top notch.
There is a reason why Emco lathes have been cloned so often by the Asians. Emco lathes are not copies of anything but they are definitely copied. Most 9x20 lathes are copies of an Emco Compact 8. Many larger Asian lathes are copies or have features cloned from the Super 11; Weiss had one that could be a Super 11 in every way that mattered.
So cult? Not sure about that but Emco owners tend not to sell their machines. I sorta think I understand why.
