O
ome
Forum Guest
Register Today
Can't make much out on pic#1. Pic #2 looks like the die holder. #3 looks like the tap holder (see if the collets fit it, if so, that's the tap holder). Can't make out much from #4. #5 just seems like another shot of the die holder? Or is it another part that just looks similar?
I guess you could to this be elimination too. The drill chucks are obvious, set those aside. The tap holder is the one that accepts the collets, the die holder is the one that accepts the die adapters. Set those aside. The live center should be obvious too, set that aside. The only thing left over should be the reamer holder. I guess the question after that is, "how do I use it". Maybe someone smarter than me will able to help you there once you figure out which one it is
The taps and die holders both fit those two sliding holders on a shaft, or float. The last pic is the only holder that has a threaded top with center hole.
Jon
