- Feb 1, 2015
- 10,091
Our 35XT Nortrak diesel doesn't like to start below 40ºF. When it gets below freezing, it definitely needs the in line coolant heater. Usually, 2 hours is sufficient time. The required time will depend upon the wattage of the heater though. If left on for more than two hours, I can often start it without the use of the glow plugs.
In the winter, the primary usage of the tractor is moving snow. I have a wireless switch that the tractor heater is plugged into. I modified it by adding an external long wire antenna so I can turn it on from the front porch, 100 yds. away and on snow days, it is the first thing I do when I get up. To make sure the switch has been activated, it also turns on an LED light mounted on the outside barn wall for a visual indication of state.
Our ancient Ford 8N has always been a beast to start in cold weather. It has an updraft carburetor and floods easily so getting the choke just right is difficult. I have an in line coolant heater on it as well with the same setup as the Nortrak. To differentiate between the indicator lights between the two, I have a green filter on the Nortak light.
For conditions where you might need to start the vehicle first thing in the morning, a timer could be used instead. That way, you don't have to run the heater all night prior to starting the vehicle.
