- Nov 26, 2017
- 1,529
Thank you very much for sharing all of this with us. I have compiled most everything you put in here into Excel, creating a BOM and a pictorial list of each of your posts. Not sure if or when I will get started on this. Still going back and forth between buy and build. My plan is to use it for commercial purposes. I have several busy concepts I am looking at.
I have a couple of questions:
1) If you were to build a unit that can handle a 4'x8' sheet, would you use 3"x3" 80/20 instead of the 2"x2"?
2) Why did you use the stud roller on the side opposite the stepper motor instead of the linear guide? Seems that you would have a more stable platform as the tool gets to farthest point from the stepper. But I am just guessing here.
3) What kind of torque is required by the stepper motors to drive this? I assume that all NEMA 23 motors are not equal.
4) Most of the purchased tables I see use a height motor. Is this not necessary as the design assumes very little change in material gage?
