In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Yes, the electronic gizmo is used to test the movement timing and beat. It receives ticks from the GPS system and compares with the clock ticks via acoustic or optical transducers. Also there is a Temperature and Humidity sensor.
