- May 2, 2021
- 330
Well - I don't (completely) blame you for the confusion.
Keep in mind - there is an element of unknowns for me - and there is also an element of discovery for all of us.
I ran the test - exactly as you prescribed - and it delivered some interesting results.
I probably listened more carefully than you realized.
You noted that I should watch out for big jumps that might be caused from a single burr or hole - so I made sure that I wasn't measuring that.
But my understanding of that direction had its own consequences.
When I saw the sudden jump of the indicator needle - I assumed it must be the burr or hole you warned me about.
I made sure not to measure that exact point when giving my readings.
It never occurred to me that the sudden jumps were something other than specific small issues in the taper surface.
Until the tech showed me - "hey, if it was a hole or a bump, then when I reverse the spindle with my hand - it should bounce back the exact same way"
That's when I cottoned on that I had an erratic issue - rather than just a surface issue with the taper.
It's a process.
It's a process.
