IF those are the generic (read cheap Aliexpress type resistors), your asking for a catastrophic VFD failure. Good quality resistors from reputable manufacturers have a isolation voltage rating often in the 500V - 2kV range. I Hi-pot tested a bunch of those cheap ass resistors and many failed at low voltage, some with very low voltage. Zero chance I would connect Ali type power resistors to 380V.
With power off and fully discharged, I would unscrew and isolate those resistors from the heatsink and see what happens. Their not going to overheat for the testing you're doing. If that happens to solve the problem order a quality name brand resistor like Dale, Ohmite.
