- May 2, 2021
- 330
Here was my process after a little fooling around - no particular order.Ok, I have questions...
1.). What size of round stick did you use (I'm assuming it is round)?
2.) Is it a rubberized stick or solid?
3.) How is it chucked into your mill (can't see from the picture angle)?
4.) How much down pressure?
1. I use CNC - but could be done on manual. My overlap in the linear direction was .4" (the stick round is .5" so this is .1 overlap with each circle. My rows are overlapped .33 each so a little more overlap in one direction that the other. You can fool around with this to your liking.
2. I used 1/2" cratex sticks. Bought off Amazon. One stick has lasted me a ton of time. Corse for a bit more texture. https://www.amazon.com/gp/product/B07WC5K963/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
3. I chucked it up in an ER collet chuck. I lift the knee until I can see some deflection in the stick. This ensures contact. Every 4 or 5, I bumped the knee up to keep good contact as it wears. A spring loaded chuck would have been ideal.
4. Edges wear the stick quickly - so when it goes over holes or finishes a row it carves down the stick a little. I would always lift knee after.
5. I kept it sticking out about 1/2" from the collet. maybe 3/4. Its stiff enough. I was able to use it down to 1" of length or less doing this.
6. Its a rubberized stick with grit in it. Cool product. Made it easy to execute.
7. I found the parts looked even better if I polished them out first.
Method: s
A. surfacing tool if I could get them on the mill.
B. 220, 400, 600, 800 grits on 3" orbital sander. Didn't take much, just a few passes each.
If I couldn't surface with mill, then I started with 80 grit. Took casting marks out. Went pretty quickly too.
I'll take some credit for collaboration - but Jim Dawson had the vision.THAT is utterly beautiful!!
Think this one had been rumbling around in his mind for a while.
He was kind enough to share.
What I like:
The color next to it really pops.
The texture isn't so delicate I can't use the damn lathe!
