- Feb 8, 2014
- 11,187
Yup, I missed that one.Apparently you missed my reply #256 (Pg 26). That was PRE-regrind.
Thanks. Was hoping my post my elicit a few better options. Learned a lot along the way. Was a helpful process.That's crazy. Give these guys a call. They redid mine for <$1K, and I have virtually the same spindle that you do.
Make sure they know it's a Bridgeport clone machine.
C & M Precision Spindle
World-class Spindle Repair Services and Spindle Rebuilding since 1993www.cm-spindle.com
When I use a coaxial indicator - it continues to bounce even if it is inside a baby smith ID bushing.I don't quite understand what you're saying there. Taper runout has nothing to do with locating the center of rotation, as witnessed by the very congruent runout data you published earlier. Now, if the bearings/spindle have become so UN-stiff that the center of rotation is noticeably moving around while hand turning a DTI . . . I guess I would call that dead in the water.
Yep - spindle numbers are a stopper.Those spindle rebuild numbers are tough OK.
Another option, put out feelers for another mill, same model. Doesn't matter if it runs. You already have access to procedures to evaluate the condition of the spindle taper and stiffness.
I still recommend that you do, on your mill, the evaluation I described in reply #256 (Pg. 26). The experience should be educational and show you what you don't want to find in another.
Have you noticed my new signature line? LOL
You guys lost me on this one a bit.Apparently you missed my reply #256 (Pg 26). That was PRE-regrind.
I don't know what a "baby smith ID bushing" is but I'll assume the ID is precisely cylindrical with a fine surface finish. If my assumption is erroneous, please advise.When I use a coaxial indicator - it continues to bounce even if it is inside a baby smith ID bushing.
The description is indicative of bad bearings. For the purposes of this discussion, "bad bearings" includes bad bearing mountings.When I turn the spindle, using an indicator - it turns and then occasionally just jumps 3 tenths - but if I reverse it - it doesn't go back to what it was - which it should - if the feeler point was falling into a hole or popping over a high spot.
That is a particularly pessimistic view. LA is a huge used machinery market with many dealers. All I suggested was "put out feelers.I would expect any and all to potentially have similar issues.
That's an admirable objective. I suppose it depends on exactly what you mean by "improve".That said - I would like to improve mine.
I don't have any experience with a Blake coaxial indicator. I think they are .0005" reading indicators. I would use a .00005" reading indicator to evaluate the bearings and housings.I am fairly (but only fairly) sure the inability to get my Blake coaxial indicator to settle down properly is due to the bearings.
Not well described so not germane.You guys lost me on this one a bit.
I can get some movement if I put an indicator on a tool and grab the tool and push/pull it.
I'm not certain of what the regrind did. Based on your comments, it didn't improve the runout and now you see erratic eccentricity which you attribute to "bad bearings". Cause unknown. On the other hand, the runout data you provided, pre re-grind, seemed to describe relatively smooth circular elements (no erratic readings).Did the regrind remove the meaningfulness of this excersize?
It was there before - and remained after the regrind.
The NOSE-PIECE (48) has nothing to do with mounting the bearings.I assume the bearing tightness is determined by the nose cone?
Address what? Reply #256 said nothing about taking anything apart or making any adjustments. If you read #256 and need additional clarification, please reply with photos illustrating the problem.Ext - did your post #256 address this in some manner that I am missing?
Step away from the cutting oil.Oh - and signature line? Must be sniffing too much cutting oil- I don't see any signature at all.
Indeed. It would seem spell correct got the best of me - should have read baby SMOOTH.I don't know what a "baby smith ID bushing" is but I'll assume the ID is precisely cylindrical with a fine surface finish. If my assumption is erroneous, please advise.
Not sure the disconnect.That's an admirable objective. I suppose it depends on exactly what you mean by "improve".
Given that you declined to do the procedure in reply #256 (pre-regrind), I don't know what to suggest or expect next.
Just to clarify - the erratic conditions were there prior to the taper grinding.I'm not certain of what the regrind did. Based on your comments, it didn't improve the runout and now you see erratic eccentricity which you attribute to "bad bearings". Cause unknown.
Jim mentioned his experience with bearing tension.The NOSE-PIECE (48) has nothing to do with mounting the bearings.
Got it.Locknut #39 sets the preload on the bearings. But you can't get to it without dropping the quill out of the head.
To put this in perspective, at $5000 I would fix the thing myself, at about $1000 I would send it to a shop. It's not rocket surgery, but I'm lazy.
Did we know we were getting the extra components?
certainly was a good (and very generous) find.
thanks Jim.
I don't recall you reporting erratic indications earlier. The runout data table was the most definitive spindle condition information published here and certainly didn't demonstrate erratic readings.Just to clarify - the erratic conditions were there prior to the taper grinding.
The the tech who worked on the machine also mentioned it - and said the nose piece is tightened to tension them.
My comments were based on what I understood to be the method.
