Randy, I tapped the four corner holes in the base of my mill and installed jack bolts [machined square on top] with rubber feet at the bottom end. To level the mill just takes a pinch bar under the corner you need to lift, a little pressure to take some of the load off the jack bolt, turn and level. The rubber feet are very stable and help the machine run much quieter than otherwise. Works well for me -- Jack
