- Jan 25, 2015
- 2,554
Tool holder rack is PETG.
Those are old pics, I have built more since. That's ABS.
Also a couple additions to the machines themselves. Got tired of needing the wrench to tighten and loosen the mill drawbar so:
Printed it off (petg), machined the interior bore to a slightly loose slip fit, melted an appropriate sized twelve point socket into the plastic and now I can drop the handle on the mill and turn it easily to loosen/tighten the draw bar.
Decided to print a few gears for the lathe and the mill:
Those are for the atlas 10F (ABS), but I printed off a couple of the "infamous" plastic gears that are in the mill head (also in ABS). Nice to have spares and to be able to print one off if I ever need it. Much better than waiting days to weeks to get a replacement.
And yes, 3d printing is a great big rabbit hole. Once you start, it sucks you all the way in........and there's literally no bottom. Seems like there's always a better hot end, filament feed method, or some other "upgrade" you'll think you just can't live without. Then there's the endless miles and miles of filament you'll need to run through it to make whatever it is you want to make.
Bottomless pit it is.....
