- Feb 15, 2024
- 60
Weiss, Grizzly, Precision Matthews, Hi-Torque, and more are all just Seig resellers.
The G0758 is just a Seig X3.
negative.Weiss, Grizzly, Precision Matthews, Hi-Torque, and more are all just Seig resellers.
OK, thanks — what I call a "Bench Mill," one step up from a Mini-Mill.negative, it is a Weiss design, similar to the pm 25/30/grizzly G0704, just smaller like a 3/4 g0704
kind of a gray area when to comes to the G0758, the G0704/PM25MV that applies but the G0758 is 13-1/8 in the X and 5-1/2 Y with about 8 max spindle to table stock so down really close to the Mini size.OK, thanks — what I call a "Bench Mill," one step up from a Mini-Mill.
the G0781 is clearly a Mini and it has 11-3/16 x 5-1/8 Y and 11-1/2 spindle to table sooo.
the biggest diff is that the G0758 has a true quill.
yea not knocking a mini mill just saying that the separate quill is a dividing line between small/bench and mini IMO,Regardless of the table size (my Mini-Mill has the same basic specs as the G0781, but I added a 2” riser so more useable height), having the separate Quill & Head movement is a big deal and the construction of this configuration is more rigid.
Totally agree; once you mentioned "quill," I figured you were referring to a Bench Mill. Even though Grizzly refers to the G0704 as a "Mill/Drill," I've always classed Mill/Drills with round column's.yea not knocking a mini mill just saying that the separate quill is a dividing line between small/bench and mini IMO,
I always thought that knee mills were mills and non-knee were mill/drills i see references to PM940s as Mill/Drills. and that mill/Drills were divided up into round column, square column and subset of minis. come to think of it is the inclusion of a quill the dividing line between mill and mill/drill? ok thanks now i have a migraine. the one mill that is not a mill/drill would be the horizontal mill. OOOOOW where's the aspirin.Totally agree; once you mentioned "quill," I figured you were referring to a Bench Mill. Even though Grizzly refers to the G0704 as a "Mill/Drill," I've always classed Mill/Drills with round column's.
I guess I shouldn't mention Micro-Mills?I always thought that knee mills were mills and non-knee were mill/drills i see references to PM940s as Mill/Drills. and that mill/Drills were divided up into round column, square column and subset of minis. come to think of it is the inclusion of a quill the dividing line between mill and mill/drill? ok thanks now i have a migraine. the one mill that is not a mill/drill would be the horizontal mill. OOOOOW where's the aspirin.
ooooooow! POOF!!!!
