Lynn,First and foremost, I don’t want to buy a TDS-420 and then have the upgrade drop (like, I did with the Rev. 2.0). The possibilities of having additional inputs and then outputs that will allow me to control things. Very cool.
Short term, my two Rev. 2.0 adapters needs the firmware to be upgraded (sent back to you) then I need to add external connections for the tachometer on the lathe and a touch probe on the mill.
Thanks,
Lynn M.
All I can say "man, did you pick the wrong DRO" You realize that I will not stop making cooler versions of the hardware if I can help it. I already have an idea for TDA-420 for the next year...
That said, you have this option: https://store.touchdro.com/products/touchdro-v3-firmware
Not free, but also works out cheaper than buying the same adapter now.
Regards
Yuriy
