Had some fun in the shop today. I have always had to hunt for the right shim to use with my cutters for the lathe. So,today, I measured the floor of the four-post tool holder to the center of a test piece mounted in the 3-jaw chuck and found it to be .525 inches. I found some aluminum that measured just about right when I set the cutter on the aluminum and used the height gauge set to .525 inches. Then, when I two-part epoxied the cutter to the aluminum and cut/filed the right side of the enhanced cutter smooth I was very happy with the result. The cutters are the type with the soldered-on tips which won't be changed from sharpening. I looked at some hss cutters I had ground and could see that they might be reshaped during sharpening or I might grind them to a different cut. So I didn't do anything with them.
As you might well guess, I don't have a qctp to precisely adjust the height of the cutters, but, I am quite satisfied with these cutters now being quick to grab and knowing they are on center for cutting.
NodakGary
NodakGary
