- Nov 25, 2015
- 9,250
so I'll offer the solution that allows you to use the backer plate as a nose protector, I was hoping you would try the methods outline earlier. but I feel this is worth saying.
Trim the plate down to about an inch larger than the spindle.
Now you can get a parting blade behind it easily.
use your parting blade to relief cut the back of the plate near the register, you only have to get near the register, and only up to the spindle even 20 thou short of the spindle.
That should remove the pressure that is holding it on. I had this problem with my tailstock, the screw was jammed in, and people were telling me to put a monkey wrench on the quill, and the screw (both would ruin the pieces so what's the point). Someone smart chimed in to just relieve the back of the tailstock quill and it would remove the pressure. BINGO.
I don't think your problem is a chip. I'm betting its totally jammed on and the register is putting so much pressure on the threads they are locked.
I have been there when the chuck was not fully on and I turned the lathe on, jamming it to that same point.
That's why I offered my original post. BTW putting a hex in a 3 jaw and wrenching the hex will not damage the chuck, it's what it's made for. Putting a wrench on the jaw can in fact damage the chuck. So go get a Big joiner bolt for hanging all thread (easy hex) or if you have a hex piece .. and get this done. I am sure the weight will work with less effort, But do jam the bull gear with a wedge, don't break a tooth with the back gears.
