Single Point Threading Between Centers
Beautiful threads! Nice work. Single point threading gets a lot faster after the first 10-20 times you try it. Starts to become routine.
For chamfering the corners of a hex head, I like to use a threading tool. Each side is a 30 degree chamfer tool and you can hit both edges in the same setup (assuming of course the dog wasn't there). It ends up looking pretty darn close to factory.
I did that at the beginning and end of the threads. Thanks for the tip.
I had a problem. I saw that I was able to make cuts as deep as .20 mm (10 divisions on the metric scale). After taking my son to work and then returning to the project, I dialed in 10 divisions on the Imperial scale. This is 30% more of a cut, and it busted my threading blade. Look at this carnage:
I will try to recover from this, but I think part of the OD is gone.
This is why I can’t have nice things.
Erik,
I think we can blame your son for this one for "taking you out of the zone". ;)
That's the type of tool that just gets ground flat on top to present a new edge, right?
-brino
My Dad came over, saw this & said that I have scrapped the work. Just as a learning experience, I am going to try to recover.
I grabbed this 60° preground HSS bit, and I put it in the tool holder so that it fits into the threads that I have cut so far. My half nut remains engaged.
Looking at the photo up close, I can see that I need to make an adjustment.
Erik,
-brino
Yes, it must be ground flat on the top, just as it came from the factory. That’s what the mill & carbide end mills are for.
There we go. Hopefully the fishtail on the tailstock quill is good enough. At present, the OD of my threads are serrated.
You sure about that......???
Dressing it flat using a grinder (or belt sander if you've got one) is the way to go for these.
Trying to do it on the mill sounds like a recipe for disaster.
Well, at least I crashed into the dog driving pin.
Oops...
+1 for just holding it in your 3-jaw.
Using a hammer and a bench vice, I temporarily fixed the offset dog driver pin bracket. It will be re-engineered.
I carefully made some cleanup passes, and I went in another .10 mm (in two passes). I tested the nut, and it was too tight.
I wanted to file the OD, but since the half nut remains engaged I had to move the tailstock quill all the way out (6”) and do the filing as the carriage advanced.
Here it is before I clean it up more.
