Way cool ! You couldn't make that on a cnc if you tried !I had a problem. I saw that I was able to make cuts as deep as .20 mm (10 divisions on the metric scale). After taking my son to work and then returning to the project, I dialed in 10 divisions on the Imperial scale. This is 30% more of a cut, and it busted my threading blade. Look at this carnage:
You must have a bench grinder, right?
Just use that, no worries. Costs free dollars and it'll work great.
I respectfully disagree.The Aloris P6 HSS insert has to be ground dead flat on top. You cannot do that with a wheel.
David,@erikmannie I have this one and it works well.
I don't know why I haven't used my Aloris threading tool-like yours??Here is how it is going. The thread relief OD is 16.1 mm for a minor diameter of 16.933 mm.
Those puppies are over $1000 in Canada...David,
I went with the Kalamazoo.
I probably should have gone on the cheap but I do like it.
These belt sanders are very handy for all sorts of things.
2FSMS 2 Inch Sander With Full Guard
Upgrade your projects with this 2 inch sander with full guard. 1/2 HP 1PH 115V motor & 4500 SFPM belt speed make quick work of almost any project. Shop now!kalamazooind.com
