- Jan 25, 2015
- 2,558
Any of the Gilletes with the number dials on them.Once I found the right blade for the razor and my face, it was smooth shaving. The wrong blade is horrible. I had been using the razor for 11 years with few issues. Tip, don't shave if you aren't awake... Trust me on that. That's when I had the issues.
@twhite who are you addressing? It seems you are a safety razor collector. I'm a beginner safety razor shaver, that's why I had the Merkur 180. There's apparently different sorts of razors for different beard types. I remember trying an old Gillette in my twenties and it was too aggressive. That's a nicer way of saying my face was cut up. Can you recommend any less aggressive old razors? Can't believe I am asking this, I can see the rabbit hole getting larger and larger...
The ones without slectable agressiveness are usually at about a ”3”, which is about as aggressive as I use.
success or failure with straight razors or safety razors are more about technique than it is equipment. The advice I offer beginners is to hold the razor like its made of rice paper. The lighter the grip, the better the shave. If you have to go over an area once of twice more is much better than pushing on one pass and striking blood.
The only thing I am critical on with equipment is the blade. Too dull and you end up using more pressure which causes burn or blood. sharp blades and a two finger hold is about all you will ever need.
