- Aug 6, 2015
- 3,896
Probably 316 is more corrosion resistant. I have some 304, so that's what I'll use.
As for the bottom, don't know yet. Probably keep it simple unless there's an issue.
I need to order the material to make the bottle cap openers... so might as well get the material for the base... it's all about the base, about the base...
Don't know about bead blasting. Right now there's walnut shells in the blaster cabinet. Changing over is a bit of work. I do have glass beads. Will that frost the stainless?
I do not know the answer to that... all I have is a cheap soda blaster gun/setup that I was going to try on the stainless steel material...
