Thank you, @SouthernChap . I completely agree with your point about being mindful of the context when considering recommendations here. From what I've learned through BlondiHacks and this community, starting with pre-ground HSS tools seems like a smart move, especially for a beginner like me. I’ll definitely take it slow and only buy what I need, as you suggested. Thanks again for the thoughtful advice!BlondiHacks pretty much tells you what you need and when to buy it in her https://youtube.com/playlist?list=PLY67-4BrEae-qwNQ3II1G1ZdUFdFYnEYO&si=uGyAoFHQSPCPbUNM playlist.
She also provides a list of where she got her stuff.
And you have the advantage of living in the same country as her (when she made these videos) and unlike me for example (I'm in the UK), don't have to try (and often fail) to find local alternative suppliers.
Okay, those videos were made 3 years ago but most of the recommendations will still be valid.
Be circumspect regarding some of the recommendations on here regarding what you need and the level of quality. They'll not be wrong per se, but they may only be valid in the context that the recommender is in, and not in your context as a beginner. People will understandably often think about what they use now and not think back to what they quite happily got along with when they first started.
Lathe cutting tools for example: start off with a set of decent quality pre ground HSS tools (HSS, not the brazed carbide ones). LMS sell them and those will be fine to start out with.
You don't need to be faffing with inserts when you start out and the pre-ground tools will also give you a visual idea of the cutting edge angles and clearances for when you come to grind your own HSS tooling.
Nothing you'll be doing at first will be affected by the shortish delivery wait when you find you need something and don't have it, so go slow and buy only what you need (see my comments about the BlondiHacks playlist above).
My advice and comments are always meant to help! They have night classes. I would recommend looking into it and seeing what they have. You might be surprised. I teach at one place where you pay for about 4 months of access and can come anytime they are open, which is 8-9 pm, M-Th. At the community college, they have a class that meets twice a week from 4-10 pm for 8 weeks.No offense, @ARC-170, and you're absolutely right about the value of taking a class to gain proper knowledge and skills. The only issue is that I’m no longer in my 20s and don’t have the luxury of dedicating that much time to formal learning, especially since I will never use this knowledge for a living; it's just my hobby. While I understand the risks and benefits of a structured environment, I’m trying to balance learning with other responsibilities. For now, I’m relying on forums and YouTube. That said, I do take safety very seriously and appreciate any advice on avoiding mistakes.
Yes but it can be quite annoying to not have the right tool for the job then trying to wing it. That's typically how I get injured.Another suggestion. Don't buy everything under the sun. Only buy what you need for a given project. Over time you will amass a lot of tooling that you will use.
Good list. I'll add Adam Booth (Abom79) ...When I started down this rabbit hole I was just like you. I didn't know squat about machining. I stumbled onto Mr Pete's videos. IMHO he is the best of the best for learning the basics of how to operate a lathe. He is a retired high school shop teacher and knows how to teach. Start with his first videos and work your way through them. It will be time well spent.
mrpete222
My channel is devoted to the wonderful world of MACHINE SHOP! I have about 950 video demonstrations on the Bridgeport mill & South Bend, Atlas, Clausing, and Logan Lathes. There is also groups of videos on the subjects of FOUNDRY, MODEL ENGINES, TRACTORS, ANTIQUE ENGINES & much more. 52...www.youtube.com
#1 MACHINE SHOP TIPS tubalcain playlist #1 thru #100
Share your videos with friends, family, and the worldwww.youtube.com
#2 MACHINE SHOP TIPS tubalcain playlist #101 thru #200
#3 MACHINE SHOP TIPS tubalcain playlist #201 thru #300
#4 MACHINE SHOP TIPS tubalcain playlist #301 thru #400
Go through the various play lists I linked to and watch what seems pertinent to what you need to learn to know how to do some task.
Have fun with your new lathe.
