- Jun 7, 2019
- 455
If off hand grinding tools is not your thing ( it’s definitely not mine) old tool and cutter grinders are cheap at auction. Makes grinding HSS lathe tools simple. Perfect angles easy to set up. I have a Rockwell multi-axis vise on an ancient Covel grinder I bought for $50. One of these days I’ll find a Monoset at a price I can tolerate and upgrade. When buying a TC grinder make sure you get the accessories you need. They will end up costing you a fortune piecing them together from eBay. I grind all sorts of tools for my turret lathe tooling which are 1/8-3/8” tiny to 1.5x1” giant tools for the big Cinci shaper. Hone with a cheap diamond stone from Amazon then finish with a good oilstone. Makes for some great surface finishes. Once you get a set of tools ground it’s easy to keep them fresh with stones as long as you don’t abuse them. There are lots of sources available for guidance. I like the tool grinding guide from Norton. That said, having at least a few options in carbide is necessary for peeling scale and any hard material turning you might do. The Warner stuff is also very interesting but I haven’t tried them. For inserts I go to high positive carbide as I am running industrial lathes with 5-10 HP and do a little commercial work that pays for modern tooling.
