Hello folks,
Continuing on my casual search for a lathe, stumbled upon a Clausing 12 x 24 model #5904 that is listed as a 'tool room' lathe.
This is not the first time I have heard this reference - but I am curious: What makes a lathe a 'tool room' lathe?
Thanks in advance!
I wouldn't get too hung up on "tool room" lathes.
When they were new, some of the items mentioned, more toys, more accuracy on this spec or that spec, they were designed for a purpose that went beyond production work.
Assuming that we're talking about older stuff, production machines turned out bearing fits, slip fits, press fits- They did what needed to be done to turn out excellent final products This doesn't imply that production machines were "sloppy". On the contrary, in their day, they were good.
When the equivalent tool room machine was made to a better tolerance, you need to not loose perspective. As accurate as it takes to do what is asked of it is pretty accurate. If you said a tool room lathe was made to half of any given tolerance, it's NOT twice as accurate. It's small numbers, asymptotically approaching no error, (which in the real world will never happen). Dividing that error of a "regular" lathe is SUCH a small amount....
For a NEW lathe, a tool room spec might be a lot nicer. For a USED lathe, the starting difference (in the accuracy department) is SO small, that the wear and overall condition will dictate how good or poor a lathe might be in actual use, or how much "fixing" it might need. Or in other words, when measuring five, ten, twenty, fifty, or however many years of wear, the initial tolerances are so small that they'll get lost in the noise of the actual wear. And in the "extra toys" department, there's a similar problem. Once the machine is used, the question is not "what extra toys did it come with", but rather "what toys come with the actual specimen that is currently for sale. A lathe that "came with" a collet closer, collet set, and a taper attachment is not worth a dollar more than the same lath without those toys, UNLESS the stuff is still there and functional. And likewise, a production (or workshop) lathe that did not come with those toys, but has been equipped with them... Well, that's worth something.
So yeah... Take the "tool room" thing for what it is today, and not what it was.
And while you didn't ask, I'm saying anyhow.... If I didn't already have a smaller lathe that suits me, if I had enough space, and if the price fell within my budget... I'd be pushing people aside for the first crack at assessing the overall condition of just about ANY lathe from that series..... If they're in good shape, they're good machines.
