- Nov 14, 2016
- 3,260
Wheels seem to be more of an issue for a lathe, as moving it around can impart twist to the bed. Many small lathes 7x16" > are just mounted to a board, workbench or cabinet and this doesn't seem to create a noticeable issue. This more due to the small size just making any deviation less apparent. Simply the error over the 10" or so working area compounds far less than a lathe with 30-40" between centers.
This seems to be much less of an issue on a milling machine, although you need to be very careful with a mobile base under a milling machine as they are top heavy, so a tipping hazard.
