What Did You Buy Today?
Me too. I've gotten good at making single flute countersinks. I also get good results with D-bit countersinks, they're easy to make for any angle, but tricky to center on the mill table compared to a full conical c'sink. Best finish bar none is O-flute. O-flutes aren't picky, as long as the cutting edge has a little bit of lead. Multi-flute c'sinks chatter no matter what, so I only use them for deburring or chamfering if I have to using a hand drill. They're great for that, because they tolerate misalignment well.
I bought it to use on the mill for de-burring and chamfering holes, wanted carbide so I can run it a bit faster which I usually get better results from.
Here it is, Made a mistake, it is 3/4"... still shinny though...
View attachment 446730:cool:
Jeff, do you run it slow. Now that I have a vfd, I find it so much easier to chamfer using counter sinks, 45 cutters, and round overs. I dial it all the way down to 250 or so for a hole.. Or I will do about 1000 for a traveling cut, but feed slowly. But it all depends I guess on the material, and the rigidity of the setup. I also have been using climb cuts more often, so it floats out of the cut, rather than dig in.. it took me a while to adopt that stance. Now I finally understand.
I'll have to try making one. I have a D-bit grinder
You can almost get away with zero back clearance on a D-bit countersink... almost.
I knew I had a pic somewhere. I made up several of these in different sizes of drill rod (but O1 works too). I ground different angles on each end to cover the usual 45 and 60 degree sinks. They work very well, other than the caveat that D-bits are slightly harder to eyeball alignment on. They also work as spot drills, but they take occasional sharpening because spotting is rough on the tool tip.
Didja know I like D-bits?
And to clarify how I grind the single facet leade and back clearance (applies to ALL D-bits), here's a drawing.
The grey is the bit, the white space is ground away. The green shows that the facet is a 15 degree step.
A Diana 45 in .177. This is one of the better German air rifles from the eighties. She is a real sweat shooter, especially with the diopter sight I pulled out of my parts bin. Air guns are great because I can shoot them in my basement before my wife gets up in the morning.
I'm jelly!
John, is this drawing from the shank perspective, or is it for use in one of those left-handed lathes I keep hearing about?
Brian
Those multi flute countersinks work fine as long as you feed them hard enough. I view them like parting tools - turn slow feed hard
I do well running at 500 to 800 RPM for bearing and chamfers but the HSS counter sinks do not survive that in the mill, I will let you know how the carbide does. I have a .500 90 degree chamfer cutter for the straight edges which works well for that.
