- Apr 29, 2019
- 2,211
Not machine related but still a new to me toy.....
Now to buy all the stuff to finish the build.
Sweeeeeet!!! EDF or Turbine?Not machine related but still a new to me toy.....
2:1 PWR? ooh-eck that thing is going to be a monster and a handful!It will have a Jet Central Lynx 130 se Jet turbine engine.
The finished plane should weigh around 15 lbs and the turbine has 30 lbs of thrust. It will be fast.
It has 54.3 wingspan and is 61 inches long.
no it doesn't if its separate. The only thing that shuts it off if the control box, not the regulator.the regulator I'm talking about is a separate unit that has nothing to do with my Quincy compressor. it mounts in the air line on the wall above the compressor. if I want less pressure, I turn a T-handle and it bleeds off air until it reaches the new setting. the compressor then shuts off at that setting, be it 180psi or 30 psi. to increase pressure the reverse is done.
Insurance is required. Caught W/O and you will end up in court. The court will tell you to get an SR22 from an approved insurance peddler. It doesn't matter if you have a vehicle or not. SR22 insurance is high risk/high priced. State requires you maintain the SR22 insurance required for 3 years. Failure to follow the court order will get you behind bars. It is very expensive!How does that work in Nebraska?
Forgive me I do not accept your brush off; you are now in the land of miss information and bad advice kills people, Compressed fluids are dangerous/deadly even at lower pressures.Pressure switch / Pressure regulator, both were used to mean the same thing when I was in the industry.
Yes, I can see how that could be confusing but we knew what we meant.
Also, it was also referred to as "de-rating" if the pressure was set lower. Just how it was when I was in the industry.
Works that way in Texas also.Insurance is required. Caught W/O and you will end up in court. The court will tell you to get an SR22 from an approved insurance peddler. It doesn't matter if you have a vehicle or not. SR22 insurance is high risk/high priced. State requires you maintain the SR22 insurance required for 3 years. Failure to follow the court order will get you behind bars. It is very expensive!
