- Aug 19, 2023
- 979
One thing to bear in mind when setting pressure regulators on compressors...
**Some** not all, but some pressure regulators, allow for the kick-out and kick-in pressures to be set separately, others, the vast majority in fact, only allow setting both at the same time, so by lowering the kick-out (turn compressor off) maximum pressure, you are also lowering the kick-in (turn compressor on) pressure.
If you DO derate to a lower pressure (that is what lowering the max pressure is termed as) and intend to keep it at that point permenantly, you should change the safety valve to match the new max pressure, even if the tank is rated for higher pressure.
Depending on the tool and how many CFM is used by said tool, you can actually inadvertantly run the compressor more by lowering the max pressure than if you left it alone.
My own compressor was sold as a 10bar /145.3PSI unit. I derated it to 8 bar and switched out the safety valve for one to suit the new max pressure. Given what I use it for, it has never been a problem.
