- Nov 26, 2017
- 1,536
Good job. Sounds like they came out perfect.
It shouldn't bind it at all unless you have the holes out of alignment. Either way should be fine. You can always test them by inserting a short way first to ensure you have your movement.
You could also ream out the moving block and use set screws to hold the rods in place.
