I've got a piece of round aluminum which has a 1/4" wide by 1/4" deep slot axially milled into it. I need to make the same size slot 180° on the other side, problem is I don't have a mill
I could try it on the my drill press using a chucked end mill or mortising bit, the spindle does have a DIY drawbar so it won't fall out, but it's hard on the machine, even with lots of light passes.
I have a mini lathe with a milling attachment, not sure if the vise is big enough to hold the workpiece, and there's barely enough cross slide travel, I may have to stop and and move the piece in the vise.
My best bet is having someone with a mill do this, I'll keep trying to locate someone.
Suggestions solicited, thank you!
