- May 13, 2019
- 1,016
Thanks, it sort of took shape on the fly. The dimensions were dictated by the angle plate.
The guide rods are socket-head shoulder screws that I had on hand, running in bronze bushings.
The jaws are 1" thick, the fixed jaw is 3 x 7.25, the moving jaw is 2 x 6
Yes, that is a 1/2-10 Acme threaded rod.
I've been thinking about building this and a few things come to mind.
1. I might change the orientation of the jaws so the height is lower. This would make it a lower profile and give it more lateral support. For my smaller mill, I'm thinking 1.25" high and 1.5" wide closer to what This Old Tony did.
2. Is an Acme thread needed? I would love to try and make one, but it looks a little intimidating for the larger sizes. I would tap the hole and cut external thread on my lathe. Is 1/2-10 Acme doable with a tap? It looks like the forces are much higher for Acme threads vs 60 degree threads.
3. Are the guide rods threaded in or pressed in? I was thinking of using drill rod and pressing them into the jaw, but I need an arbor press.
