- Jun 12, 2014
- 4,996
Does the DRO show a change in position, assuming you are using the cross slide to advance the cutter and the compound is locked. Check the gibs on the cross slide/compound, also the back of the carriage. Might also recheck the head alignment, do you see the same taper when cutting a diameter and does this change under load (DOC)?
