- Jun 7, 2013
- 10,403
Insert (carbide) tools are rarely sharp on the cutting edge and that results in increased tool pressure which can result in taper. I use HSS tools from Aloris that are sharp and easily sharpen able and adjustable for helix. They are available in several widths and pitches (width of flat on the end). They are sharpened ONLY on the top. and last for years in regular frequent use.Answering the last 4 questions -
Threading tool has been a mixture between a standard laydown, and a Mesa Tool vertical (threading away from headstock).
Lathe is an Eisen 1440EV
Everything is tight - Aloris Toolpost
Chuck is a True Bore Alignment System with a Gator 6 Jaw - barrels are indicated in as close to zero as possible - typically only reading .0002-.0005 when done dialing in. After threading, all is still tight and dialed in within range.
Tool height and squareness verified.
