Yesterday my Trident Serial number request was granted so we have an official Voron now.
I installed the doors and panels. The Voron panel snap-clips are excellent! I used them on the sides and top to facilitate removing panels for service or for printing PLA which needs better cooling. The handles on top do interfere with panel removal so the sides are easiest to remove, but even the handles only require 4 screws so much easier than removing a full set of the normal panel screws. I'm not sure how useful the handles will be, they are a bit high to use for lifting.
I did a thermal test of the heated bed for 30 minutes at 80C and the internal temperature reached 45C by the end when the thermal protection timer shut them off. That is adequate for ABS and ASA.
I was able to get 240mm in X, Y and Z. One might be able to get a little more but it might require some customization like drilling new holes or remaking some plastic parts. Not worth my time to pursue. If you need more than 240 then build a 300 Trident or V2.4, or a 350 V2.4. I have the 360mm Prusa XL if I need more build volume, but it's not too often that is needed. The overall size of the 250 is a good compromise for my purposes. It takes less workspace than the Prusa MK4 since the bed doesn't move back and forth.
For reference, this is a Voron Trident 250 Rev A kit from LDO, I did add a StealthBurner toolhead and 2 piece toolhead PCB. The newer kits probably include this. This one came with mostly Afterburner parts for the older toolhead. I bought the SB toolhead already built from Formbot with a Dragon SF hotend, but the included toolhead PCB was not compatible with the LDO cabling. So I procured the LDO Hartk 2 piece toolhead boards and changed those. The LDO cabling plugs directly into them. The plastic functional parts came from the Voron PIF program, but they were procured before StealthBurner was released, so they included older Afterburner parts. Parts beyond the functional parts were printed with PETG on the Prusa MK4. I think they will hold up to the chamber temperature but if not they can be replaced with ABS/ASA. Most of them are external anyway, only a few are inside, these are mostly LDO specific parts that didn't come in the original set such as Wago mounts and LDO PCB mounts. The kit did not include a Raspberry Pi so I used a Pi4 2GB model I procured separately. Even 1GB of memory is plenty, this is using under 300 MB of ram now, so a Pi 3B would be adequate.
LDO kits provide high quality parts, well packed and labelled. It is a bit fiddly following the excellent Voron instructions and LDO exceptions together.
