- Aug 19, 2023
- 1,285
The motor torque requirements for knurling are higher than for cutting threads. So you need a better motor, which is usually larger. And you usually need a higher voltage power supply to power that motor. And you have to repackage that stuff to fit on your lathe. If the lead screw motor had the required torque, an ELS can handle it, it's no different than feeding.
My intented question was "is it easy to knurl with an ELS or harder".. I should phrase things better.
Seems it may be harder, even when hand cranking since in most cases, the ELS (so far as I have seen) disconnects the gear drive between spindle and leadscrew.
