- Nov 14, 2016
- 3,332
As to the two machines, it is not as simple as just build quality. They are similar, but distinct machines with different specs.
728 has a 5 year warranty vs 3 years on the 727
728 has 2 DRO options, both using magnetic scales, the 727 has one DRO option using optical scales
728 has slightly more travel 10" Y, 19" X vs 727 with 8.5" Y and 15" X, both have 16" Z.
727 is significantly heavier 475lbs vs 370lbs for the 728
727 has a 1.5hp motor vs 1hp on the 728
728 has a larger RPM range 100-4000 in 2 steps vs 40-3000 in 6 steps (maybe an advantage to the 727 at low speeds?).
727 is 7" taller than the 728 75" vs 68" (both on the 32" factory stand)
The 728 has a worm gear to set the head tilt, the 727 you loosen the bolts securing the head and manually tilt it to the desired position.
This is simply based on reading through the specs and looking at the manuals. I have not used either of these mills.
