- Jun 17, 2016
- 349
What did you weld that with? What machine/set up?
HTP Pro Pulse 220 MTS. 035 diameter 4043 wire, 20lb spool loaded up inside the machine. Set-up is as described in the previous post.
It's hard to beat an old AC welder
Bring it! I'll put up my little lunch box against any tombstone.It's hard to beat an old AC welder
A good friend of mine sails on Lake Erie. We were talking about sailing one year and he said he would put his sailboat in a race against any speed boat on the lake in a trip to Cleveland, OH (from Port Clinton).
How is a sailboat going to have any chance of beating a speed boat you think?
Easy. The speed boat will run out of fuel. A speed boat won't go with no fuel. At which point it runs out it will be dead in the water.
As for welders - when things go down - how do you "raise the sails" to keep on keepin' on? Thats where the old school stuff comes in to play.
Speaking of which... there are a couple inexpensive Lincolns around here. One is a round top Idealarc 250 - AC/DC version - that looks to be in decent shape for its age. I'll let ya know what I come up with there.
Later down the road I want to be able to do TIG and MIG, but I don't want either as options on a stick power supply. I just want stick, thats all. It will be a good back-up machine if I get a better unit for MIG and TIG later.
If that's the case then immediately go look at the Lincoln IdealArc 250's you mention above. A bulletproof stick-only machine that your grandchildren will pass on to their heirs.
