I really like stick welding for heavy structural stuff outside in the wind/rain/snow (yes I did have a pleasure to weld in all of those simultaneously...).
But for thin gauge sheet metal, if you want to do it quickly there is no substitute for MIG. One of my first proper MIG welding projects were big sliding garage doors for my workshop. They were so heavy I built the frame with square steel tubing on the floor with TIG (teaching myself TIG at the time), but the sheet metal had to be welded in place. I had to use thin sheet metal. 1mm (40 thou - 19 gauge I think) panels 2.5m (7.5ft) tall by 1.2m (4ft) wide. They had to be welded all around and there were 3 panels per door side. Inside was a breeze. I loaded 35 thou gas shielded MIG wire and it welded great. But the outside... There was wind, and rain, and I had to finish it. I bought self shielded wire and it was really difficult at first. I must have welded and ground off a lot of that wire before I got (sort of) the hang of it. Eventually I did weld the outside well. I ground it and sanded it so it looks like one big sheet of metal.
Then there is TIG. There is no better welding method IMO for aluminium, magnesium, various castings, cast iron (tig brazing with silicon bronze) and of course stainless.
So these days my go to method is MIG, then TIG then stick.
Also, anyone with a stick welder and a big air compressor I recommend to try carbon-air-arc gouging for "disassembly" of stick welds. It's a lot of fun.
