- Sep 7, 2019
- 674
Strap wrench update.
The threads went pretty OK. I ended up having to make an unthreaded portion on the end because there's still some aluminum in the threads of the nut. With this, I miss that galling.
Pardon my surface finish. I tried to dish out the end a little to grab the strap more securely.
Scratch pass. Looks good.
The thread cut just fine. I never checked with thread wires, though I do have them. I just kept trying the nut. I ended up having to knock down the peaks a good bit to get it to thread in. The final OD is around 0.714"! Ugh...
I sanded up the head part.
I tried it out with some smooth seatbelt style nylon I had. This was a take off from my kayak when I changed seats.
I doubled it up so I could put a pin in the loop. If you really pull on it, the strap pulls free form the threaded handle.
Well that's about it. I guess I'd call it done though it doesn't work as well as I'd like. The grip isn't all that tight. When I loop the strap around and feed it back through, it doesn't pinch to the head very strongly and slips. I rounded the head over pretty good because I didn't want the strap to cut or fray over time but maybe I should have left it with more square edges. Or maybe I need a thicker, stiffer strap material?
