- Feb 9, 2017
- 5,597
Not even heard of magnetic brakes but I'm not in the fab world anymore and 80% of what I did was in the field during an install.Ah the slotting of the bend line is a great trick! Especially if you have access to a plasma.
Have you seen magnetic bending brakes? That's some cool stuff there! I don't have a good way to bend metal right now so every now and then I lok around at options.
I'm not sure of where I got the tab cut idea but it was certainly out of necessity. I don't think you could do those kinds of tab cuts without a plasma. We had a small plasma and mig that I did all my field fab with and I loved that setup so much I copied it for my small home shop. All my stuff is geared for the lighter end so my little Hypertherm 350 and Lincoln 175T work perfectly and can do heavier work but fit on one old small HF cart. The only example of that kind of tab cut is the front cover I replaced the old plastic cover on the front of my RF30 when I put a DRO on it.
