Did a little lathe maintenance today as well.
I've been unhappy with the gear mesh for the power feeds on my old Atlas. The selector has an adjustable plate such that when I adjust it to a good mesh for the left carriage feed the right carriage feed just barely meshes at all. This has led me to rarely use the "right traveling" power feed. This isn't really a big deal but unfortunately the right carriage feed is also the cross slide "in" feed so I rarely used that either.
What I had to do was make a new plate with new holes so that I had good mesh in both settings. The old plate is on the bottom
and my newly made one is on top. Mine has no adjustment possible but since I drilled the holes to allow for good mesh I don't think it will matter.
Here's the old one mounted. The screws are not in but you get the idea. Notice on the above pic how my new holes are spread farther apart from center. I'm guessing this is because of wear in the gears. I'm sure when it was new the old plate was just fine.
I couldn't really get a good pic of the gear mesh but the way I set them both was to bottom out the teeth using the selector then back off a bit so they had some little bit of backlash.
It seem to run well. All the feeds work and now I can use all the feeds without worrying about gears slipping or striping out.
What do you guys like for lubing gears? I heard automotive gear lube is good, the 90W to 140W variety. I didn't have any so I smeared some heavy grease on 'em.
