- Jun 29, 2014
- 4,188
Background:
Been paying $80/month for 10'x12' storage unit for two years. Enough! Decided to build a shed. Had my son design it and come up with the materials list. He is a second year civil engineering student at Norwich so we figure this will be a good experience for him. Although he was helping me build my shop 7 years ago, running the air nailer for the second story. Anyhoo, I digress... I'm building a shed...and gawd! I don't want to dig and pour concrete sonotube footings! In desperation, I read about these Pylex screw pilings and there appears to be two choices: heavy duty sizes for about $350 each installed, or DIY version for about $50/each. Before anyone tries to dissuade me, I'm committed and going to make it work!
Each piling is rated for static load bearing of 5,000#. I don't like how the pilings can potentially sway, and in the Northeast, I have to go below the frost line. The base units are 50" long and you can purchase a 24" extension to get real deep if need be.
Installation is pretty straight forward, according to their website and Youtube, an 8' 2x4 can be used to wind these into the ground. After having purchased 8 pilings (for a 10' x 14' shed) I was having second thoughts about how easy these are going to be to screw into our gnarly Vermont backyard with lots of roots and rocks.
So, I decided to go the power route. I have a Porter Cable corded impact hammer for changing tires. Pylex does sell an adapter, but nobody had one available - not that it matters - I'm a hobby machinist!
Build & Photos
A 1/2" drive 3/8" socket, 1-1/4" round, 1" square bar. Drilled the round through up to 1/2". Bored one side 3/4" diameter about 1" deep. Bored the remaining 1/2" end to accept the 3/8" socket side of the socket later for welding. Then I turned a 3/4" stub on the square rod, about 1" long. This was then used in a square collet block on the mill to quickly mill the 1" square down to the inner diameter of the Pylex tubes, which are swaged square with .840" inner square dimensions. Then I welded everything up and then turned the square corners down to the point where they square drive fits inside the tubes clean. See photos below.
Finished.
___________________________________________________________________________________________________
Welded socket. Hope it holds!
Square end. This was milled on a square collet block, corners turned (interrupted cuts) and imperfections filed out to make sure I had clearance.
____________________________________________________________________________________________________________________________________________________________
Drops right into the swaged top of the piling.
And installed on the impact driver.
Was a good day to do this project, it has been raining off and on all day, so we will start the pilings tomorrow. Wish me luck!
Build & Photos
Finished.
