- Apr 30, 2015
- 11,885
Shame about the speed control- up till then it looked like you were in the clear
If there are no serious mechanical/machining problems you still are doing better than most
Some of these things are such a mess you'd be just as well mining the ore yourself
If it has a brushed 90 volt dc motor (two wires) I would just toss the original speed control and install a KB electronics SCR drive.
KBIC-120 and 125 are two models that have proven to be very reliable- around 100$ or less on Ebay. KBs were used as OEM
on some models of import lathes in the past- they're solid. Good to 1 HP with no additional heatsink. Good low speed torque.
Tip: get the older version using thru-hole components rather than surface mount parts- easier to repair
(not that you would need to very often)
