- Apr 21, 2015
- 690
Like everyone else in this thread, I'm fascinated by the video.
I'll trust anything Robin has to say absolutely -- the man's a wizard.
But why was a diamond wheel in a surface grinder the only method that worked for him to make them? He didn't report what other methods he attempted, but the first that comes to my mind is lapping on a diamond plate like this one (it's how I used to flatten water stones for sharpening woodworking tools).
How flat do they have to be to work the way he shows in the video?
I'm very curious to see how flat you're able to get your stones. Please take the time after you grind them to measure them on a surface plate with a tenths indicator (use a gauge block on top to eliminate the surface roughness).
I'm curious to see how flat I can get a stone by lapping it on my diamond plate (not sure how flat my diamond plate is, but I'll check that first). If the diamond plate isn't flat enough, I'll follow up with sandpaper on a granite surface plate. If that doesn't work for some reason, I might try some coarse carborundum grinding grit on a temporary lap (just a piece of cast iron durabar that's been scraped flat -- not my box parallel!). (Somewhere I acquired several film tubes with different grits.)
If I have time, I'll try some experiments tomorrow. I'll report back how far I get without a surface grinder. I think I've got a couple stones I can experiment with.
